Introdução
If your device is unable to store information, you may be in need of a new or upgraded SD card. This guide will outline how to properly remove the SD card without damaging other parts of the device. The difficulty of this guide is very easy and it will not require any prior experience.
There is no SD card in the pictures but the area where the card is stored is clearly identified.
O que você precisa
Using a plastic spudger or finger nail, Open the port labeled micro SD using a plastic spudger or finger nail.
Uma outra pessoa concluiu este guia.
