Ir para o conteúdo principal
Samsung Galaxy Tab A 9.7 Rear Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab A 9.7 Rear Camera Replacement, Rear Camera: passo 1, imagem 1 %32
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 2, imagem 1 %32
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 3, imagem 1 %32
    • Remove one of the iFixit opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 4, imagem 2 %32
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  5. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 5, imagem 2 %32
    • Disconnect all wires and strips that connect the motherboard to any other part of the device with an iFixit opening tool.
    • Lift up gently on all wires and strips.
  6. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 6, imagem 1 %32
    • Lift the motherboard out of the back panel using an iFixit opening tool.
    • Be gentle when wiggling the motherboard out from underneath the battery's protective edge.
  7. Samsung Galaxy Tab A 9.7 Rear Camera Replacement: passo 7, imagem 1 %32
    • Pull off the rear camera on the back of the motherboard and replace.
Conclusão
Makenzie D'Elia
Membro desde: 04/09/19
313 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G3, Hovde Spring 2019 Membro de IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 262
