Ir para o conteúdo principal
Samsung Galaxy Tab A 9.7 Headphone Jack Replacement
O que você precisa
  1. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32
    • Pry along the edge of the Samsung Galaxy Tab A 9.7 with an iFixit opening tool.
  2. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 2, imagem 1 %32
    • Insert a second iFixit opening tool along the edge and begin to pry open the back cover a little with each one.
  3. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 3, imagem 1 %32
    • Remove one of the opening tools and begin to go around the device with the other one until the back cover pops off.
  4. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 4, imagem 1 %32
    • Disconnect the strip from the motherboard with the iFixit opening tool.
  5. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 5, imagem 2 %32
    • Remove five 2.8 mm screws using the Phillips #000 screwdriver.
  6. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 6, imagem 2 %32
    • Remove both side pieces using one of the the iFixit opening tools.
    • Lift up the headphone jack port with the iFixit opening tool as well.
  7. Samsung Galaxy Tab A 9.7 Headphone Jack Replacement: passo 7, imagem 1 %32
    • Pull up the headphone jack port carefully and replace.
Conclusão
To reassemble your device, follow the instructions in reverse order.
Justin Osborn
Membro desde: 04/09/19
154 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G3, Hovde Spring 2019 Membro de IUPUI, Team S1-G3, Hovde Spring 2019
IUPUI-HOVDE-S19S1G3
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 427
