Introdução
If the glass on the screen of your Samsung Galaxy Tab A 9.7 is cracked or damaged in any way, your device could be nearly unusable. This guide will help you replace the display glass in an easy and safe way.
O que você precisa
Microwave the iOpener for 30 seconds.
Place the iOpener on each side of the screen for 30 seconds.
4 comentários
incomplete.
Not a good tutorial.
The following steps are completely missing:
- remove the backcover with a pick or Spudger running between back cover and body.
- flip up the lock for the flex cable with a spudger
- slide the flex cable through the body and remove the display
- slide the flex cable of a new display throught the body to the backside
- connect the flex cable to the connector (be aware of correct aligning) and flip down the lock
- glue the display back to the body (do not use much pressure as it may crack the new display!)
- clip back on the back cover
