Ir para o conteúdo principal
Samsung Galaxy Tab A 9.7 Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab A 9.7  Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: passo 2, imagem 1 %32 Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: passo 2, imagem 2 %32
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7  Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab A 9.7  Battery Replacement: passo 3, imagem 2 %32
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7  Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab A 9.7  Battery Replacement: passo 4, imagem 2 %32
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7  Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab A 9.7  Battery Replacement: passo 5, imagem 2 %32
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
Conclusão
13 outras pessoas executaram este guia.
Paulina Nguyen
Membro desde: 04/26/17
982 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S1-G3, Livingston Spring 2017 Membro de Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Membro
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 61
Duração total: 11,209
