Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
During all steps, handle every component with care as they are very delicate electronic parts.
Peças
Nenhum componente especificado.
  1. Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  3. Carefully remove the back panel from the front to expose the components inside the device. The volume buttons are located on the back panel shown in the red box.
    • Carefully remove the back panel from the front to expose the components inside the device.
    • The volume buttons are located on the back panel shown in the red box.
  4. Take your tweezers and gently push volume buttons loose from the panel. Take your tweezers and gently push volume buttons loose from the panel.
    • Take your tweezers and gently push volume buttons loose from the panel.
Conclusão
Uma outra pessoa concluiu este guia.
Bradley Watson
Membro desde: 15/02/2017
773 Reputação
4 Guias de autoria
Equipe
USF Tampa, Team 5-4, Passmore Spring 2017 Membro de USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 619
