Ir para o conteúdo principal
Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement
O que você precisa
  1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: passo 1, imagem 2 %32
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 2, imagem 3 %32
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 3, imagem 3 %32
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, imagem 1 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, imagem 2 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: passo 4, imagem 3 %32
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
    • Use the plastic opening tool to remove the motherboard from the case.
  5. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: passo 5, imagem 2 %32
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while prying upwards until the screen separates from the bezel.
    • The screen may crack during this process so be wary of broken glass.
    • Applying heat may be necessary to loosen the glue.
Conclusão
Guneet Bawa
Membro desde: 04/12/18
658 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G5, Liner Spring 2018 Membro de UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 3,079
