Introdução
If the audio is not playing, even after following the troubleshooting instructions, then you may need to replace the headphone jack using this guide.
Ferramentas
Peças
Nenhum componente especificado.
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
Flip up the two ZIF connectors on the motherboard using the plastic opening tool.
Slide the orange ribbon cables out of the ZIF connectors.
Remove the front-facing camera.
Use Phillips # 000 to remove two of the 4 mm .3 cm screws around the headphone jack.
Lift the metal piece that is covering the headphone jack from one of the sides.
Lift out the headphone jack.
2 outras pessoas concluíram este guia.
2 Comments
where can i buy a new piece of headphone jack for my tab A?
Amazon sell them here: https://www.amazon.co.uk/FoneJoy-Genuine...
