Introdução
If you are having issues with keeping a charge or your battery is dead, use this guide to properly replace the battery in your Samsung Galaxy Tab A 10.1.
O que você precisa
Vídeo de Apresentação
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
BEWARE!!! later on Samsung tablets the tab holding the main cable (marked “MAIN”) breaks as soon as you attempt to lift the tab to remove the ribbon! I reckon Samsung designed this breakabloe tab to not only avoid the warranty, but the render the tablet useless!
Happened to me also, in order to replace that broken tab, do you think it will be necessary to replace the motherboard? I highly doubt we can find the parts to fix (replace) the flip-tab.
LOOK what I found!!! its the replacement for the connector we broke!!!https://www.parts4repair.com/samsung-gal...
i just wonder how u gonna solder this tiny thingie
I wish I had read this thread before I removed the cable and broke the connector. Unfortunately I have not been able to reattach the cable and my tablet is dead.
If there is no way to remove this cable, why is this fix even posted here? I find this exceptionally uncool!
Whoever broke the connector was trying to open it the wrong way. I have oil spilled in mine after I replaced my screen and digitizer together if you only replace the screen it is more difficult. I say changing both together is simpler. And I will share a pic either way I just might mess up MY connector. To be continued
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
46 outras pessoas executaram este guia.
9 comentários
Used this guide up until the disconnecting of the battery in order to fix the black screen of death. Very very helpful. Thank you.
If you have my kind of bad luck — where the latch for the battery flex cable connector sticks to the tape when you remove the tape, and then it will not snap back into place — don’t worry about it too much, because the connector tension will hold the flex cable in place. Just put the tape back over the top as directed.
Why does it say you need a heat gun?
To loosen the adhesive. A hair dryer works well too
how to calibrate the new battery?
when device switched off due to 0% of battery - there is impossible to boot it even with charging. there is required to open a tablet and charge the battery from another source.
Used this guide when the device was charging, only showing the charging symbol and it would not turn on. The screen was flickering as well, still wouldn’t turn on. However, this guide helped immensely! Fixed it in a few minutes! Take your time with the clips and make sure that you remove the lever before slowly pulling out the ribbons! Easy Fix!
Thank you for the guide it worked a treat, no problems what so ever (touch wood).
Man beachte, dass um das Glas herum zwei Kunststoff-Lippen laufen. Wenn man das Werkzeug zwischen das Glas und die innere Lippe steckt, würde man nur das Glas abheben. Man muss das Werkzeug zwischen die innere und die äussere Lippe stecken!
AWESOME!! I was trying to open it from the “NOT OK” place and you saved me to broken the screen… thanks!!
David Leiva - Responder
No problem, enjoy.
Roger L. Ortiz -
Felt it was easier for me to do it from the middles out.
Tanin Garcia - Responder
@rogerlortiz You two seem to be miscommunicating. The author points out the location between the digitizer and frame in which to place a tool. While @Tanin Garcia, whom no longer seems to be member, was pointing out where along the edge from corner to corner it was best to start the separating process.
B. A. Computer Services -
Important: the display is sourrounded with a plastic frame. You need to get beween this frame an the backcover (not directly at glass edge as I tried it first and almost broke the glass). Get a closeup picture of it to clarify.
Oliver Dawid - Responder
wer lesen kann, ist klar im Vorteil - ich hab die SD-Karte drin gelassen. Hat aber funktioniert…
Thomas Wolter - Responder
Don’t use a very small flathead screwdriver as a spudger. Just shattered the screen :(
nikvoss - Responder
Yes, shattered the screen. To the garbage, it goes. A little knowledge is a dangerous thing. This a repair better suited for a professional repair! Thanks for helping me make the decision to get another one!
vancega - Responder
