Ir para o conteúdo principal
Samsung Galaxy Tab A 10.1 Back Panel Replacement
O que você precisa
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: passo 1, imagem 2 %32
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab A 10.1 Back Panel Replacement: passo 2, imagem 2 %32
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
Conclusão
9 outras pessoas executaram este guia.
Isabella Li
Membro desde: 10/02/17
2.364 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S15-G6, Livingston Fall 2017 Membro de Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
Membros da 4
Autoria de 26 guias
Um comentário
Why need to remove cables when only the back has to be replaced ?
nabe_03 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 74
Duração total: 11,733
