Ir para o conteúdo principal
Samsung Galaxy Tab A (2019) Screen Replacement
O que você precisa
Instruções em vídeo
Conclusão
17 outras pessoas executaram este guia.
Nick Myers
Membro desde: 04/15/18
3.501 Reputação
Autoria de 25 guias
9 comentários
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - Responder
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - Responder
Use a heat gun it will help that’s what I would do
nicholaswiding -
I tried this with a hairdryer. While there are probably options that work better, it still helped a lot. I am too much of a coward to use a heat gun, as I don't want to fry it, so I used my wifes hair dryer to the point where the tablet was very hot to the touch around the edge of the screen.
Kristian Jarmund -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 50
Últimos 30 dias: 243
Duração total: 14,066
