Introdução
This guide will walk you through the process of replacing a broken, frozen, or unresponsive display screen on a Samsung Galaxy Tab 8.9.
O que você precisa
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Ferramenta utilizada neste passo:Tweezers$4.99
Using tweezers, peel away the green tape located on top of the two flexible ribbon cables.
