Ir para o conteúdo principal
Samsung Galaxy Tab 8.9 Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: passo 2, imagem 1 %32
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: passo 3, imagem 1 %32
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: passo 4, imagem 1 %32
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, imagem 1 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, imagem 2 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: passo 5, imagem 3 %32
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 8.9 Battery Replacement: passo 6, imagem 2 %32
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab 8.9 Battery Replacement: passo 7, imagem 3 %32
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, imagem 1 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, imagem 2 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: passo 8, imagem 3 %32
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: passo 9, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, imagem 1 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, imagem 2 %32 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: passo 10, imagem 3 %32
    • Use a spudger to lift up and separate the battery from its housing.
Conclusão
4 outras pessoas executaram este guia.
Dan D
Membro desde: 09/25/14
160 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 11-4, Blackwell Fall 2014 Membro de USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
Membros da 4
Autoria de 10 guias
Um comentário
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 4,515
