Ir para o conteúdo principal
Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, imagem 1 %32 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, imagem 2 %32 Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Opening the tablet: passo 1, imagem 3 %32
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Disconnecting the camera: passo 2, imagem 1 %32
    • Detach the ribbon cable from the flex cable.
  3. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the flex cable: passo 3, imagem 1 %32
    • Detach all ribbon cables from the flex cable, unscrew the flex cable, and remove the flex cable. This needs to be done in order to remove the camera which sits underneath the flex cable.
  4. Samsung Galaxy Tab 7.7 Rear Facing Camera Replacement, Removing the camera: passo 4, imagem 1 %32
    • Replace the original camera with the new camera. It should come right out.
Conclusão
Uma outra pessoa concluiu este guia.
Stephanie Wong
Membro desde: 09/26/14
973 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-2, Staggers Fall 2014 Membro de USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 680
