Ir para o conteúdo principal
Samsung Galaxy Tab 7.7 Flex cable Replacement
O que você precisa
  1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: passo 1, imagem 1 %32 Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: passo 1, imagem 2 %32 Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: passo 1, imagem 3 %32
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: passo 2, imagem 1 %32 Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: passo 2, imagem 2 %32
    • Unsnap all the ribbon cables from the flex cable.
  3. Samsung Galaxy Tab 7.7 Flex cable Replacement, Unscrewing the flex cable: passo 3, imagem 1 %32
    • Remove the screws securing the flex cable to the chassis.
  4. Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: passo 4, imagem 1 %32 Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: passo 4, imagem 2 %32
    • Remove the original flex cable and replace it with the flex cable.
Conclusão
Stephanie Wong
Membro desde: 09/26/14
973 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-2, Staggers Fall 2014 Membro de USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 818
