Ir para o conteúdo principal
Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement
O que você precisa
  1. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement, Front Panel: passo 1, imagem 1 %32
    • Fully power off the device.
    • Disconnect and remove any cables that are connected to the device (i.e. chargers or headphones).
    • Place the device on a flat, stable, and clean surface.
  2. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 2, imagem 3 %32
    • Remove the plastic tabs on the bottom of the device using the metal spudger, as shown in the pictures.
    • Make sure you have a place to store small parts like this where they are easily accessible but hard to lose.
  3. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 3, imagem 3 %32
    • Using a Tri-Point YO Screwdriver, remove the two 4.1mm Tri-Wing screws.
    • Place the removed screws in a location similar to where you placed the pads that you removed in the previous step.
  4. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 4, imagem 2 %32
    • Wedge a plastic opening tool between the front and back panel, on the bottom right corner.
    • Slowly push the tool down to make a small gap between the front panel and the back panel.
    • Holding the tool steady, run the tool along the bottom part of the device from right to left. This will make the gap between the front panel and the back panel bigger.
    • When wedging your tool into the device, make sure to apply the pressure to the screen and device at a slow but steady speed to the screen. Too much pressure too fast can crack the screen.
  5. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 5, imagem 2 %32
    • Leave the previously used tool wedged in the device.
    • Insert another plastic opening tool into the bottom of the left side, as shown.
    • Using a similar procedure to the last step, run the tool along the side and widen the front panel-back panel gap. This time, run the device from bottom to top.
    • Repeat this process for the right side of the device, starting at the bottom of the right side.
    • Some of the other tools that you wedged in may pop out. Simply wedge them back in where they were previously, and continue.
  6. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement: passo 6, imagem 2 %32
    • Holding the bottom of the device, lift the front panel from the back panel.
    • Make sure to remove the front panel slowly, to ensure that you don't accidentally break anything.
  7. Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement, Volume Button: passo 7, imagem 1 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement, Volume Button: passo 7, imagem 2 %32 Samsung Galaxy Tab 7.0 Sprint Volume Button Replacement, Volume Button: passo 7, imagem 3 %32
    • From the outside edge of the device, carefully push the volume button inwards towards the middle of the device.
    • Make sure to not push too hard. If you push too hard, the button might slip and hit the parts on the inside close to the button.
    • Once the button is out of its slot, carefully remove it from the device.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure all parts are aligned properly before attempting to put them back together.
Peter Van Ausdeln
Membro desde: 01/19/17
606 Reputação
Autoria de 6 guias
Equipe
UC Davis, Team 1-2, Rodger Winter 2017 Membro de UC Davis, Team 1-2, Rodger Winter 2017
UCD-RODGER-W17S1G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 147
