Ir para o conteúdo principal
Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement, Rear Case: passo 1, imagem 1 %32
    • Before you being the replacement process, make sure the tablet is completely powered off.
    • Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
    • Right-handed users will probably be more comfortable prying in a clockwise movement, while left-handed users will feel more comfortable doing a counter clockwise movement.
    • When taking off the rear case there will be periodic clicking noises. Do not worry about those noises. They are just the rear case being disconnected.
    • Be careful not to use too much force as the plastic clips can easily be broken.
  2. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • Place the tablet screen down on a clean surface.
    • Grasp the back panel and lift it from the device.
  3. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement, Rear Facing Camera: passo 3, imagem 1 %32
    • The rear facing camera will be located just to the right and below the front facing camera, near the top and center of the motherboard.
  4. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Slide the flat end of the blue plastic opening tool underneath the rectangular metal connector of the rear facing camera.
    • Apply slight pressure outwards until the camera's metal connector pops from its socket on the motherboard.
  5. Samsung Galaxy Tab 4 8.0 Wi-Fi Rear Facing Camera Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the camera from it's housing with your tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Cameron Morrow
Membro desde: 04/14/16
384 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 25-3, Maness Spring 2016 Membro de Cal Poly, Team 25-3, Maness Spring 2016
CPSU-MANESS-S16S25G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 322
