Ir para o conteúdo principal
Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: passo 1, imagem 3 %32
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: passo 2, imagem 2 %32
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: passo 3, imagem 2 %32
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Conclusão
Uma outra pessoa concluiu este guia.
Ofelia Cruz
Membro desde: 09/14/15
1.119 Reputação
Autoria de 5 guias
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 902
