Ir para o conteúdo principal
Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: passo 1, imagem 2 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Rear Case: passo 1, imagem 3 %32
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 2, imagem 2 %32
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 3, imagem 2 %32
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
  4. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: passo 4, imagem 2 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement, Battery: passo 4, imagem 3 %32
    • Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
    • Remove the sticker to form a tab.
  5. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 5, imagem 1 %32
    • Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
    • If battery resistance is encountered due to adhesive, use the flat end of a spudger to run in between the battery and the front panel assembly.
    • Do not completely detach the battery just yet, doing so can cause damage to the red and blue cables loacted at the bottom of the battery.
  6. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 6, imagem 2 %32
    • Starting at the bottom left side of the battery, gently remove the green tape.
    • Salvage the green tape if the replacement battery does not include one.
  7. Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab 4 8.0 Verizon Battery Replacement: passo 7, imagem 3 %32
    • Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
    • Lift the battery towards you, away from the front panel.
Conclusão
17 outras pessoas executaram este guia.
Ofelia Cruz
Membro desde: 09/14/15
1.119 Reputação
Autoria de 5 guias
Equipe
CSU Fullerton, Team 1-3, Bruce Fall 2015 Membro de CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
Membros da 4
Autoria de 12 guias
3 comentários
Everything in this guide looks pretty good. The only thing I would add to step one is to make sure you remove both the SIM card and the Micro SD card. Failure to do so can result in a broken SIM/SD card, slot or board they are connected to.
Cameron - Responder
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
Jason Stephens - Responder
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
Carlos Blanquer Bogacz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 25
Duração total: 26,236
