Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Motherboard: passo 1, imagem 2 %32
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 2, imagem 3 %32
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 3, imagem 3 %32
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 5, imagem 3 %32
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 6, imagem 3 %32
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 7, imagem 3 %32
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 8, imagem 3 %32
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement, Front-Facing Camera: passo 9, imagem 3 %32
    • Flip the motherboard over to view the back side.
    • Locate the front-facing camera on the motherboard.
  10. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 10, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 10, imagem 2 %32
    • Use a plastic opening tool to unlock the front-facing camera wire from the motherboard by flipping-up the retainer flap.
  11. Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 11, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Sprint Front-Facing Camera Replacement: passo 11, imagem 2 %32
    • Use your fingers to grip the camera and carefully pull it out and away from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Valentina Franco
Membro desde: 10/03/16
434 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-3, Forte Fall 2016 Membro de Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 785
