Introdução
The speaker replacement is relatively easy. It is attached to the back panel and does not require any attention with the motherboard.
O que você precisa
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
In order the speaker connection, you must first peel back part of the surrounding water gasket.
With the tweezers, grab the overhanging corner and peel the gasket back slowly.
If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
2 comentários
Where can I order the new speaker?
This would be better if it were a YouTube video so we could actually see it being done.
