Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Speaker Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: passo 1, imagem 2 %32
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 2, imagem 1 %32
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Speaker Replacement: passo 4, imagem 2 %32
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
Conclusão
Aubrey Goodwin
Membro desde: 08/31/15
2.668 Reputação
3 Guias de autoria
Equipe
USF Tampa, Team 1-3, Remmell Fall 2015 Membro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Membros
12 Guias de autoria
2 comentários
Where can I order the new speaker?
Dorrie Stotko - Responder
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 3,825
