Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The motherboard is the control center for the tablet and is one of the most crucial components. Unfortunately there are only a few components that you can replace on it. If your charge port or headphone jack are compromised, it will be necessary to replace the whole motherboard.
O que você precisa
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
To begin the replacement of the motherboard, identify the wire strip connections that must be removed.
These connections can be removed using tweezers.
These chip connections can be released using the plastic opening tool.
24 outras pessoas executaram este guia.
4 comentários
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
