Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 5, imagem 2 %32
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 6, imagem 2 %32
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
    Use caution taking the board out as it does have some tabs that may hold it in place
    Andrew - Responder
Conclusão
24 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Remmell Fall 2015 Membro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
Membros da 4
Autoria de 12 guias
4 comentários
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Responder
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Responder
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 42
Duração total: 18,036
