Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 2, imagem 1 %32
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: passo 3, imagem 3 %32
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 5, imagem 2 %32
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: passo 6, imagem 2 %32
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
Conclusão
24 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Remmell Fall 2015 Membro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
Membros da 4
Autoria de 12 guias
4 comentários
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Responder
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Responder
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Duração total: 17,872
