Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Home Button Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: passo 1, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement, Home Button: passo 1, imagem 3 %32
    • Power off the tablet.
    • Using a plastic opening tool, pry open the back case by inserting the tool into the seam and moving it in the gap between front and back panel of the tablet.
    • Insert triangle opening picks into the gaps as you work to keep the back panel separated.
  2. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 2, imagem 2 %32
    • Using the flat end of a spudger, unclip the press fit connections below the battery and at the top near the camera.
  3. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pull up the locking clip of battery ZIF connector.
    • Disconnect the battery by sliding out the golden ribbon cable.
  4. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove five 1.7 mm screws from the top and bottom edges of the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to carefully lift up the motherboard and remove it.
    • Do not twist the motherboard if it does not lift out. Double check that all of the connections have been disengaged and use another technique to lift it.
  6. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • Use a heat gun or hair drier to heat up the edge of the digitizer. This may help to remove it easily. Do not heat it too much.
    • To remove the digitizer, insert and move a plastic opening pick to create a gap between the digitizer and screen.
    • Carefully lift up the digitizer a little bit and insert a plastic opening card to separate the digitizer from the screen.
    • Do not use sharp edge tool, as it may damage your screen.
  7. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 7, imagem 2 %32
    • Carefully lift up the digitizer. As you do, you will need to slide one of the press fit connectors through the midframe.
    • Be cautious that you do not sever the connector cable.
  8. Samsung Galaxy Tab 4 7.0 Home Button Replacement: passo 8, imagem 1 %32
    • Carefully remove the old home button and replace with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Bhavesh Joshi
Membro desde: 04/27/20
181 Reputação
Autoria de 1 guia
Equipe
2 comentários
Where can we buy the correct home button?
rayramirez - Responder
I ordered one from Amazon for 8$
dpachota - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 43
Últimos 30 dias: 172
Duração total: 6,189
