Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement, Back Panel: passo 1, imagem 2 %32
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 2, imagem 1 %32
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: passo 3, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement, Motherboard: passo 3, imagem 3 %32
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 5, imagem 2 %32
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement: passo 6, imagem 2 %32
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
  7. Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: passo 7, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: passo 7, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Camera Replacement, Camera: passo 7, imagem 3 %32
    • With the tweezers grab the base of the wire harness and slide it outward in the direction shown.
    • This can be done for either camera on the tablet.
Conclusão
9 outras pessoas executaram este guia.
Aubrey Goodwin
Membro desde: 08/31/15
2.683 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Remmell Fall 2015 Membro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
Membros da 4
Autoria de 12 guias
3 comentários
My camera on the Tab 4 is fine, but the len on the back is scratched. Can I get a replacement for the lens? If so where can I purchase this and is it comparable with other Tabs or Cells lens. I am not looking for a camera, Im look for the glass that protects the said camera.
Amanda Ellenberger - Responder
पॉप आर्ट मुझे चाहिये
Jagdish Mote - Responder
टॅब पार्ट खरेदी करना है मुझको
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 4,241
