Ir para o conteúdo principal
Samsung Galaxy Tab 4 7.0 Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Battery Replacement: passo 2, imagem 1 %32
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy Tab 4 7.0 Battery Replacement, Battery: passo 3, imagem 3 %32
    • You do not need to remove the motherboard in order to remove the battery as the photos may indicate.
    • Work the spudger underneath the battery as shown and pry the battery away from the phone case.
    • The battery is attached to the case with adhesive, so a bit of force is required during removal.
Conclusão
28 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 1-3, Remmell Fall 2015 Membro de USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
Membros da 4
Autoria de 12 guias
3 comentários
This is for a cell phone, not a tablet. Why?
ckmjunk - Responder
it is the tablet
sourcandysaiyan -
OH! its so easy!! woohoo, ordering battery now!
sourcandysaiyan - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 44
Duração total: 26,579
