Ir para o conteúdo principal
Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement
O que você precisa
  1. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Battery: passo 1, imagem 2 %32
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 2, imagem 1 %32
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 5, imagem 1 %32
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 6, imagem 1 %32
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: passo 7, imagem 1 %32 Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement, Power and Volume Button: passo 7, imagem 2 %32
    • Pry up and disconnect the power and volume button press-fit connector with the flat end of a spudger.
  8. Samsung Galaxy Tab 4 10.1 Power and Volume Button Replacement: passo 8, imagem 1 %32
    • Remove the power and volume button ribbon cable.
Conclusão
4 outras pessoas executaram este guia.
Blake Klein
Membro desde: 01/29/17
72.051 Reputação
Autoria de 50 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 3,840
