Ir para o conteúdo principal
Samsung Galaxy Tab 3 Password Lock/Hard Reset
Vídeo de Apresentação
  1. Samsung Galaxy Tab 3 Password Lock/Hard Reset, Power Off: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 Password Lock/Hard Reset, Power Off: passo 1, imagem 2 %32
    • Power off the tablet by pressing and holding the Power Lock button. The Tablet Options menu will appear.
    • Select the ‘Power Off’ option.
    • Touch ‘OK’ and the tablet will power off.
  2. Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 2, imagem 2 %32 Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 2, imagem 3 %32
    • Press and hold the Home button, the Volume Up bottom, and the Power button simultaneously.
    • When the Samsung Galaxy Tab 3 logo appears, release only the Power button, keeping the Home button and Volume Up button pressed. You are now viewing the Android Recovery Menu.
  3. Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 3, imagem 2 %32 Samsung Galaxy Tab 3 Password Lock/Hard Reset: passo 3, imagem 3 %32
    • Use the Volume Up/Volume Down buttons to scroll through the Recovery Menu and the Power button to select options.
    • Select ‘Wipe data/factory reset.’
    • Select ‘Yes - erase all user data.’
    • Select ‘reboot system now.’
Linha de Chegada
186 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
188.523 Reputação
330 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
312 Membros
1.298 Guias de autoria
108 comentários
thank you so much i have been locked out of my tablet for months now
zeidi - Responder
Il existe de nombreuses raisons pour mot de passe oublié tablette samsung, ainsi que de nombreuses méthodes différentes, mais vous voudrez peut-être qu'un tiers déverrouille votre téléphone, car il s'agit du moyen le plus simple, le plus rapide et le plus simple pour faire le travail. .
Jakcoaio -
for ALL that come here READ this: scroll up to under the video and click “video source”. This takes you to original on youtube. Good. Now scroll down below the vid to the description. Click on “show more”. READ. It explains very specifically near the end. I was not having success until I read and did, Viola!! It worked. I personally screen shot it to save to my other info for this device. Thought I would come back here to tell others that come here one day in the future what i found and can get it and not end up being frustrated. Good luck to all. The original poster here should have mentioned to seek out the original video. Bogus!!! “Fixit” did a terrible job.
Barb Smith -
Hi - I have tried this but it won't let me highlight the wipe data / factory reset line. It skips from the one above to the one below ... help??
Sandra - Responder
Then you select the factory reset line with volume button, you press smoothly the power on button .
Kannan -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 41
Últimos 7 dias: 249
Últimos 30 dias: 1,229
Duração total: 825,201
