Ir para o conteúdo principal
Samsung Galaxy Tab 3 Kids Speaker Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • Using the plastic opening tool to open up the device, wedge in the seam between the screen and the back cover. Slide the tool around all the edges and remove the screen from the back cover
  2. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 2, imagem 1 %32
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 3, imagem 3 %32
    • Before Changing the motherboard, you have to lift up the (ZIF) zero insertion force by using the plastic opening tool, separating the connector from the batter ribbon cable
  4. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 4, imagem 2 %32
    • Unscrew the ten 4mm PH000 bolts holding the motherboard on the device
  5. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 5, imagem 3 %32
    • Remove the mother board from the device by carefully lifting it out.
  6. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 6, imagem 1 %32
    • Remove the last screw holding down the speaker.
  7. Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 7, imagem 2 %32 Samsung Galaxy Tab 3 Kids Speaker Replacement: passo 7, imagem 3 %32
    • Remove the speaker using the plastic splunger
Conclusão
Uma outra pessoa concluiu este guia.
ajhoffman
Membro desde: 01/04/14
182 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-6, Nance Fall 2016 Membro de USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 181
