Ir para o conteúdo principal
Samsung Galaxy Tab 3 Kids Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 Kids  Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before beginning this repair, make sure that the device is completely turned off.
    • Wedge the plastic opening tool in the seam between the screen and the back cover.
    • Slide the tool around all the edges and remove the screen from the back cover.
  2. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 2, imagem 2 %32
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 3, imagem 2 %32
    • Remove the four 1.2 mm Phillips #000 screws surrounding the battery.
  4. Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 3 Kids  Battery Replacement: passo 4, imagem 2 %32
    • Use your hands to gently lift the battery up to remove it.
    • If it does not come off easily, there may be some glue underneath the battery and may need to be pried off with a spudger.
Conclusão
4 outras pessoas executaram este guia.
ajhoffman
Membro desde: 01/04/14
182 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 2-6, Nance Fall 2016 Membro de USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
Membros da 4
Autoria de 10 guias
2 comentários
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 1,988
