Ir para o conteúdo principal
Samsung Galaxy Tab 3 8.0 Speakers Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Battery - Open up the tablet: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Battery - Open up the tablet: passo 1, imagem 2 %32
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Remove Back Cover: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Remove Back Cover: passo 2, imagem 2 %32
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Disconnect Battery: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Disconnect Battery: passo 3, imagem 2 %32
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Remove Battery: passo 4, imagem 1 %32
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Disconnect Speakers: passo 5, imagem 1 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Disconnect Speakers: passo 5, imagem 2 %32
    • Disconnect the relays attached to the motherboard.
  6. Samsung Galaxy Tab 3 8.0 Speakers Replacement, Unscrew Speakers: passo 6, imagem 1 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Unscrew Speakers: passo 6, imagem 2 %32 Samsung Galaxy Tab 3 8.0 Speakers Replacement, Unscrew Speakers: passo 6, imagem 3 %32
    • Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
Conclusão
4 outras pessoas executaram este guia.
Kyle Ballard
Membro desde: 09/22/14
939 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 4-2, Brown Fall 2014 Membro de USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
Membros da 3
Autoria de 26 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,918
