O que você precisa
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Take the plastic remover tool and gently lift the component free from the motherboard.
Uma outra pessoa concluiu este guia.
