Ir para o conteúdo principal
Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: passo 1, imagem 2 %32 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, White Backing: passo 1, imagem 3 %32
    • To begin working on your repair, turn your device over and open the micro SD slot, as shown in the first picture.
    • Using the flat part of the spudger, begin pushing it between the white backing and the SD slot. Continue to pry off the white backing until you hear several clicks and see the white backing lift up, as shown in the second picture.
    • Continue to pry off the white backing around the device, as shown in the third picture.
  2. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement: passo 2, imagem 1 %32
    • Once the backing has been pried off all around the device, remove the white backing.
  3. Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: passo 3, imagem 2 %32 Samsung Galaxy Tab 3 7.0 3G Back Cover and Frame Replacement, Silver Siding: passo 3, imagem 3 %32
    • To remove the silver siding, begin by pushing the spudger between the frame and the screen, as shown in the first picture.
    • Do this until you see the silver siding begin to lift up. Continue doing this around the edges of the device, as shown in the second picture.
    • Once you silver siding is loose all around the device, remove it carefully with your hand as shown in the third picture.
Conclusão
22 outras pessoas executaram este guia.
Andrea Flores
Membro desde: 10/09/14
1.516 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-30, Maness Fall 2014 Membro de Cal Poly, Team 14-30, Maness Fall 2014
CPSU-MANESS-F14S14G30
Membros da 4
Autoria de 18 guias
7 comentários
i need the back panel
Nithyanand 333 - Responder
Awesome, I was able to use this guide to easily replace the integrated battery in my seven inch version of the Galaxy Tab 3!
segin2005 - Responder
Hello,
I cannot understand why my tablet galaxy T211 3 7.0 3G can't turn on anymore... The screen is black, i don't know is happening and all the "internet tricks" power off- sounds etc doesn't function do you have any solution?
Thank u
alizeescolas - Responder
It would be easy the said. It will only take five minutes they said. Yeah right you lying ass ##&&%. It took me 2 and a half hours to get off and it was NOT easy. Not to mention the tools I was using to get it off chipped and cracked part of the white back cover.
Queen Valencia - Responder
Never buying a Galaxy Tab again!
RoRoTX Wills - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 111,991
