Introdução
Wenn Ladebuchse oder Mikrofon kaputt sind, nutze diese Anleitung, um die Komponente auszubauen und zu wechseln. Die Ladebuchse ist mit einem Flachbandkabel zum Mikrofon verbunden. Wenn eines defekt ist, muss die ganze Einheit ausgetauscht werden.
O que você precisa
Setze ein Plektrum in den Spalt zwischen Gehäuse und Plastikrahmen.
Schiebe das Plektrum um die Kante des Gehäuses bis die Rasten, die das Display am Gehäuse festhalten gelöst sind.
Mache solange weiter, bis alle Rasten gelöst sind.
Klappe den schwarzen Sicherungsbügel am ZIF Verbinder des Flachbandkabels zur Ladebuchse mit dem flachen Ende des Spudgers hoch.
Entferne das Kabel vorsichtig aus dem Sockel.
Um dein Gerät wieder zusammen zu setzen folge den Schritten in umgekehrter Reihenfolge.
47 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
9 comentários
I'm currently working on this tablet. My friends' kids screwed up the USB port and has part of the connector inside the port missing. Somebody had pried the back of the case open breaking off all of the tabs that are melted down to secure the frame of the case better. There are tabs left that snap the frame to the back but there are places along the edge that show a gap and will now have to be glued to eliminate the gaps. So only pry the case/frame off along the edge of the screen using an iFixit opening tool.
I just received the new replacement USB port today 3/22/17. I bought it on eBay for $3.29 including shipping and took a week to get it. Everything worked out fine. The tablet receives power and charges now. I ended up using hot glue to secure the case frame to the rear of the case. When snapping the screen back on to case frame you may have to squeeze the case and the screen very hard and at the same time force the frame to snap into place.
I completely agree with opening at step 5, went back together beautifully and much easier!! :-)
Thank you! With this instruction I managed to replace the charging port within 30 minutes. Installing the rear of the frame again took most of the time. Saved me a repair of Euro 55.
