Ir para o conteúdo principal
Samsung Galaxy Tab 3 10.1 Charger Port Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Samsung Galaxy Tab 3 10.1 Charger Port Replacement, Charger Port: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Charger Port Replacement, Charger Port: passo 1, imagem 2 %32
    • Turn off the power to the device before removing the back case.
    • Use a plastic tool to release the screen from the plastic case.
  2. Samsung Galaxy Tab 3 10.1 Charger Port Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Charger Port Replacement: passo 2, imagem 2 %32
    • Disconnect the battery using a spudger. Pry up gently on both sides to release the connector (marked in green).
    • Remove the tape covering the zif connector (marked in red)
  3. Samsung Galaxy Tab 3 10.1 Charger Port Replacement: passo 3, imagem 1 %32
    • Disconnect the cable on the left of the charger (marked in green).
    • Remove the two philips screws that secure the charger port in place (marked in red).
Conclusão
16 outras pessoas executaram este guia.
Harvey
Membro desde: 02/15/16
5.235 Reputação
Autoria de 10 guias
5 comentários
Where would I purchase the charger port and what is the tell tale sign that the charger port is the problem.
Do you know how much this part is
Kind regards
Victoria
Victoria Watson - Responder
Normally you can find it online at any electronics parts supplier......or eBay. the part itself isn't too expensive but will depend which country you live in.
Harvey - Responder
Step 3 How do you disconnect the cable from the charge port?
shaneflavell - Responder
I have replaced the charger, but I have the problem that loads very slowly or the computer does not reconkce the tablet
Edwin Chévez - Responder
It could be the charger port is defective, even though it is new.
Have you tried another charger cable and plug? It will charge quicker over mains power than over USB charging.
If the computer doesn’t recognize it either, then I would guess that the new part is probably defective, if it was recognized with the old part before.
Harvey -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 9,565
