Ir para o conteúdo principal
Samsung Galaxy Tab 3 10.1 Battery Replacement
O que você precisa
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: passo 1, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement, Rear Case: passo 1, imagem 2 %32
    • Insert an opening pick between the rear case and the plastic rim.
    • You may need to add multiple picks to detach the clips.
    • Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
    • Continue to slide the pick around the edge of the rear case until all clips are released.
    I would not remove the back of the case. There are around 14 tabs inside that are melted down to secure the frame. Those melted tabs will break off and the back won't be as secure and the edge of the back will have have a visible gap showing. I would remove the case from the screen side as in step 5 of this tear down and use a iFixit opening tool. Use the tool with handle towards the screen to pry the frame away. Start on one long edge and slide the tool along the gap and at same time slightly pry the case away. Then separate a short edge. The corner between the 2 open gaps should just pop away with some prying. Do the same with other 2 edges and corner.
    Gary L. Turner - Responder
    Kommentar von Gary L. Turner bestätigt. Es geht eindeutig besser das Opening Tool in den Spalt an der Oberseite einzuführen, zwischen dem umlaufenden silberfarbenen Rahmen und dem Display Glas. Die im Foto oben unter Schrott 1 gezeigte Methode ist NICHT zerstörungsfrei. Das (weisse) Back cover und der umlaufende silberfarbene Rahmen sind zwei separate Kunststoff-Bauteile, die an ca. einem Dutzend Punkten miteinander verschweisst sind, und zwar so eng dass kein Fingernagel dazwischen passt. Diese Schweisspunkte zerbrechen bei der im Bild oben gezeigten Methode.
    Ralf Hanisch - Responder
    sry, “Schritt 1” muss es natürlich heissen, nicht “Schrott 1” ;-)
    Ralf Hanisch -
    Use the iFixIt Opener. You’ll have to find a large opening, seems like near a piece of tech is easier. Once you get a firm and deep opening, keep working it down.
    Shane - Responder
    Bitte aufpassen: Dies ist NICHT die Anleitung, um den Akku beim TAB S3 zu ersetzen, dies wird an anderer Stelle beschrieben, leider auf Englisch.
    Aber beim S-3 ist es viel schwieriger, da beim S-3 auch das Frontglas entfernt werden muß…..
    klement, herbert - Responder
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 2, imagem 2 %32
    • Lift the case up to remove it.
    Be careful around the camera if it sticks, use spudger to separate.
    Shane - Responder
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: passo 3, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: passo 3, imagem 2 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery: passo 3, imagem 3 %32
    • Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
    Remove green tape over connectors, you can put back on later if it still is sticky enough.
    Shane - Responder
    I want to purchase a tab 3 replacement battery T4500E 6800mah, should I also include the S/N number mine is TL1F109AS/9-B (CANNOT FIND A MATCH ONLINE )please help does this number really matter when making the purchase?
    Shavonise Ricketts - Responder
    No batteries available online
    Anton Berggren - Responder
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 4, imagem 2 %32
    • Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
  5. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 5, imagem 2 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 5, imagem 3 %32
    • Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
  6. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
    Um die winzigen Schraubenköpfe zu schonen verwende grundsätzlich den grösstmöglichen (und nicht den kleinstmöglichen!) Schraubendreher. Für die zehn Kreuzschlitzschrauben mit denen der Akku befestigt ist passt ein Philips #0 perfekt.
    Nachtrag: Philips #00 passt fast noch besser.
    Ralf Hanisch -
  7. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 7, imagem 2 %32
    • Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
    It seems like prying underneath the cords is better and won’t damage the motherboard’s black connector piece.
    Shane - Responder
  8. Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab 3 10.1 Battery Replacement: passo 8, imagem 2 %32
    • Lift with a nylon spudger to remove the battery.
Conclusão
75 outras pessoas executaram este guia.
Corey Brown
Membro desde: 06/24/16
8.682 Reputação
Autoria de 11 guias
7 comentários
Great, Thanks for the help. It was very useful.
nyhorseracing - Responder
why are there white lines all over the screen after a new battery was installed
Rosita Fowler - Responder
brilliant ! worked extremely well !
Carmelo Aquilina - Responder
Thank you very much for the information. I have one question, though. The new battery works, but it takes a VERY long time to charge. More than a day, in fact. Any idea what could be causing that? Is it possible that one of the connections is not tight enough? If so, which connection might that be?
Thank you.
Paul Ross - Responder
Very easy instructions. Thank you. My only snag was that the ten screws holding the battery were extremely reluctant to undo. wrecked the IFxit screw driver. Fortunately, I had another one. My tip for anyone doing this little job, is to use quit a lot of downward pressure on the screws. Turn them 1/4 turn anticlockwise and back again. Do this several times until they turn freely. You will then have an easy job. I will replace those screws with a tiny blob of 'Never Seize'.
Keith Aldworth - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 44
Últimos 30 dias: 272
Duração total: 42,959
