Ir para o conteúdo principal
Samsung Galaxy Tab 3 10.1 Battery Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Samsung Galaxy Tab 3 10.1 Battery Replacement, Open Device: passo 1, imagem 1 %32
    • Using your plastic opening tools, carefully start to pry apart your Samsung Galaxy Tab 3 10.1 all along the edge. Do this until the back side of the tablet can be removed.
    • Be careful when inserting the opening tools to avoid damaging the speakers on left and right sides. The picture actually show a dangerous position for the right (small) opening tool.
    • During reassembly, be careful not to insert bottom, left, nor right edges first—doing so can damage the power button, and prevent the front panel from sitting totally flush.
    • If screen is cracked like shown imagine, Place tape on screen to prevent injury.
  2. Samsung Galaxy Tab 3 10.1 Battery Replacement, Ribbon Cables: passo 2, imagem 1 %32
    • Gently remove tape over ribbon cable connectors and set it to the side. Using the opening tools, gently lift the connector latches to disconnect the ribbon cables.
  3. Samsung Galaxy Tab 3 10.1 Battery Replacement, Battery Screws: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the ten screws securing the battery to the motherboard.
    • Make sure to keep screws in a secure location for reassembly.
  4. Samsung Galaxy Tab 3 10.1 Battery Replacement, Removal: passo 4, imagem 1 %32
    • Pull back the ribbon cables, lift up the original battery, and disconnect the battery by exerting upward pressure from beneath the battery.
Conclusão
45 outras pessoas executaram este guia.
Fabio
Membro desde: 10/16/14
1.506 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-2, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-2, Duarte Fall 2014
UMASSD-DUARTE-F14S2G2
Membros da 4
Autoria de 6 guias
4 comentários
is there a diference between the lte, 3g and wifi versions of the samsung tablet
Josh Robinson - Responder
thanks for the information. i will use it wisely.
Adelle Bradley - Responder
Battery changed, works fine !
Thank you for the tuto :-)
Sharky Billy - Responder
Great guide thank you.
My cover is not flush, even though I carefully attached the top first then downwards - I'm just clumsy I guess.
George Cooke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 54,379
