Introdução
If you have water damage, or listen to music too loud and blew out you speakers, this guide will help you replace them. Be aware that there are many small pieces within this device, from 4mm screws to small components. This is a very simple part to replace, so there will not be too much to keep track of - only the back of the device and the speakers themselves.
O que você precisa
Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
