Ir para o conteúdo principal
Samsung Galaxy Tab 2 7.0 Speaker Replacement
O que você precisa
  1. Samsung Galaxy Tab 2 7.0 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
    • It is easy to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 2, imagem 2 %32
    • Using a phillips head screwdriver, remove the two 4mm screws holding down each speaker.
  3. Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab 2 7.0 Speaker Replacement: passo 3, imagem 3 %32
    • Locate the flex cable attaching each speaker to the motherboard.
    • Carefully use a nylon spudger to lift the cable and detach it from the motherboard.
    • Lift the speaker out of the device.
    • If the speaker does not come out easily, use a flat tool under the flex cable to slightly lift the speaker out of place before removing it with your hands.
    • Be careful when working with flex cables. Excessive force and sharp tools have the potential to damage these components.
Conclusão
Katija Tarailo
Membro desde: 03/02/17
460 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G1, Harley Spring 2017 Membro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 727
