Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Power the device down completely
Remove the SD card from the SD card slot.
Use the prying tool to separate the front and rear panels by slipping the tool underneath the screen edge and sliding it around the entire device.
Remove the battery Flex Cable from its socket by placing the pry tool under the wires and gently prying it out.
Using the Phillips precision screw driver remove the six 4 mm screws holding the battery in place.
Once the battery is loose, remove as shown.
Using the Phillips #00 precisions screwdriver, remove the 12 4mm screws holding in the motherboard.
Release all flex cable connections at the bottom section of the motherboard.
Using the plastic pry tool release connections for both loudspeakers.
Once disconnected gently remove the loudspeakers from the device.
Release all flex cables on the right side of the device motherboard as shown.
Using the plastic pry tool, release the touch screen flex cable from its socket.
With the same tool release the LCD screen flex cable form its socket.
Release all flex cables on the upper portion of the motherboard.
Using the plastic pry tool release the sensor flex cable from its socket.
With the same tool release the camera flex cable from its socket.
Release the front camera flex cable from its socket.
Release the side button's flex cable from its socket.
There is one more Flex cable to remove, it's to the right of the front camera connector (see previous picture with connector highlighted in yellow box). It connects the top microphone and headphone jack.
15 outras pessoas executaram este guia.
6 comentários
hi, i need some help for my samsung galaxy tab 2 7.0 running on stock android 4.1.2, unrooted. It boots into the home screen, and I can access safe mode too, but if you use it for long, it restarts and again and again. when I tried to wipe the data on it through the recovery mode, it says data wipe complete, but when it reboots, it has the same files as if nothing happened. I also tried flashing a stock rom to it through the recovery mode and odin, but it hangs halfway through and reboots again with the same files.
Can I replace WiFi motherboard with a SIM Motherboard?
