Ir para o conteúdo principal
Samsung Galaxy Tab 2 7.0 Camera Replacement
O que você precisa
  1. Samsung Galaxy Tab 2 7.0 Camera Replacement, Camera: passo 1, imagem 1 %32
    • Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
    • It is easiest to begin this process by starting at the micro SD card insert, as shown in the pictures.
  2. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 2, imagem 1 %32
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
    • Remove the battery, and set it aside.
  3. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 3, imagem 1 %32
    • Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
  4. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, imagem 1 %32 Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, imagem 2 %32 Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 4, imagem 3 %32
    • Locate the 8 flex cables attached to the motherboard.
    • Using a nylon spudger, gently detach each flex cable from the motherboard.
    • Be careful when detaching flex cables. Excessive force and sharp objects have the potential to damage these components.
    • Lift the motherboard from the device and set it aside.
  5. Samsung Galaxy Tab 2 7.0 Camera Replacement: passo 5, imagem 1 %32
    • Locate the camera towards the top of the device.
    • Use a nylon spudger to gently lift the camera and remove it from the device.
Conclusão
Katija Tarailo
Membro desde: 03/02/17
460 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G1, Harley Spring 2017 Membro de IUPUI, Team S3-G1, Harley Spring 2017
IUPUI-HARLEY-S17S3G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 662
