Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If you have damaged your auxiliary port because of general wear and tear or accidental damage, you can easily replace it so that you can get back to enjoying your music. However, keep track of all of the components along the way, as some are very small and very easy to lose.
O que você precisa
Using a nylon spudger or flat plastic opening tool, pry open the back of the device.
5 outras pessoas executaram este guia.
