Ir para o conteúdo principal
Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement
O que você precisa
  1. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Rear Panel: passo 1, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Rear Panel: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Place the bottom of the tablet towards you.
    • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
    • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
  2. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 2, imagem 3 %32
    • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
    • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
    • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
    • Be sure to work carefully, as prying too firmly can crack the screen.
  3. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  4. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Battery: passo 4, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Battery: passo 4, imagem 2 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Battery: passo 4, imagem 3 %32
    • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
    • Carefully pull the three ribbon cables from their sockets on the motherboard.
  5. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 5, imagem 2 %32
    • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  6. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 6, imagem 2 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 6, imagem 3 %32
    • Lift the edge of the battery up with your finger or a spudger.
    • Detach the battery by holding the motherboard down while gently lifting the battery up.
  7. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Rear Camera Flash: passo 7, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement, Rear Camera Flash: passo 7, imagem 2 %32
    • Use your spudger to gently pry up the black connection of the LED flash from the motherboard.
  8. Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 8, imagem 1 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 8, imagem 2 %32 Samsung Galaxy Tab 10.1 Rear Camera Flash Replacement: passo 8, imagem 3 %32
    • Grab the black connection with your fingers and lift it up from its slot.
    • We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this step.
Conclusão
Uma outra pessoa concluiu este guia.
Davie Sy
Membro desde: 09/30/13
1.430 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 13-5, Forte Fall 2013 Membro de Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
Membros da 5
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 6,888
