Introdução
For any number of reasons, your camera may be taking bad pictures, or no pictures at all! If it's not a software issue, then you might need to replace your actual camera. This straightforward guide will lead you through the process of replacing your camera step-by-step. The trickiest part here is removing the back panel, so just be careful there. In no time you'll be back to snapping selfies!
O que você precisa
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
The connection you need to unfasten is the orange rectangle with the black cable coming out of it. Slide either your nail or the metal spudger under that orange connection.
Gently pop the connection off the motherboard.
