Introdução
This guide will walk you through removing the back panel of the device and disconnecting the battery. Both of these steps are necessary before any other parts can be replaced. You will hear audible pops as you pry the back off of the device. Don't worry, that's supposed to happen. Focus on prying the bottom corner and two bottom edges away from the device before moving elsewhere. Doing so will make the rest of the back panel pop off the device relatively easily.
O que você precisa
Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
Continue to wedge the tool about every inch along the current edge.
5 outras pessoas executaram este guia.
