Ir para o conteúdo principal
Samsung Galaxy Tab 10.1 4G Back Panel Replacement
O que você precisa
  1. Samsung Galaxy Tab 10.1 4G Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Power off your tablet before you begin disassembly.
    • Screen side facing you, rotate device 180 degrees so the "SAMSUNG" logo is upside down.
  2. Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 2, imagem 2 %32
    • Using the plastic opening tool, start in the center near the charge port and wedge the angled tip between the plastic back and the glass screen.
    • Create a wedge and apply pressure. Use the tool to separate the screen from the back until you hear an audible “pop."
    • Continue to wedge the tool about every inch along the current edge.
  3. Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 3, imagem 2 %32
    • Once the bottom edge has been loosened, work towards a bottom corner from the other edge and continue to wedge gently until you can “pop” the corner out.
    • Continue this process on the other bottom corner until it can be popped out as well.
  4. Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 4, imagem 1 %32
    • Place your hand between the device and the back panel. Then continue the wedging motion along the top edge of the device until the back panel comes loose.
    • Do not wedge the tool directly on top of the power buttons and headphone jack. Wedge nearby so that you don’t damage internal hardware.
  5. Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 5, imagem 1 %32
    • Remove the back from the device.
    • Excessive force shouldn't be necessary here. If the back panel is sticking, find the area of the edge closest to the sticking point and wedge the opening tool there until the back panel pops free.
  6. Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 6, imagem 1 %32 Samsung Galaxy Tab 10.1 4G Back Panel Replacement: passo 6, imagem 2 %32
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • The connection between the battery and motherboard is a group of four wires in black housing that can be found near the top middle of the device. Using a plastic spudger or a flat, slim tool, lift the black connector housing upwards to disconnect it.
Conclusão
5 outras pessoas executaram este guia.
Ashley Stark
Membro desde: 09/23/15
1.220 Reputação
Autoria de 6 guias
Equipe
Baylor, Team 10-11, Williams Fall 2015 Membro de Baylor, Team 10-11, Williams Fall 2015
BU-WILLIAMS-F15S10G11
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 1,443
