Ir para o conteúdo principal
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
O que você precisa
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: passo 1, imagem 1 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 2, imagem 1 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 2, imagem 2 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 2, imagem 3 %32
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 3, imagem 1 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 3, imagem 2 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 3, imagem 3 %32
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: passo 4, imagem 1 %32
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 5, imagem 1 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 5, imagem 2 %32
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 6, imagem 1 %32
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 7, imagem 1 %32 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to pry the speakers out of the tablet
Conclusão
Guneet Bawa
Membro desde: 04/12/18
658 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G5, Liner Spring 2018 Membro de UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 313
