Ir para o conteúdo principal
Samsung Galaxy Star Pro Micro SD Memory Card Replacement
O que você precisa
  1. Samsung Galaxy Star Pro Micro SD Memory Card Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Place phone firmly between both hands with one hand flat on the back of the phone and pop off the back cover
  2. Samsung Galaxy Star Pro Micro SD Memory Card Replacement: passo 2, imagem 1 %32 Samsung Galaxy Star Pro Micro SD Memory Card Replacement: passo 2, imagem 2 %32
    • Once rear cover is off use small pastic spudger to lift battery out of the phone
  3. Samsung Galaxy Star Pro Micro SD Memory Card Replacement, Micro SD Memory Card: passo 3, imagem 1 %32
    • After following the steps for battery replacement, the SD memory card is going to be able slide right out of this slot for replacement.
Conclusão
Lance Barber
Membro desde: 03/21/16
365 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 7-2, Catania Spring 2016 Membro de UMass Dartmouth, Team 7-2, Catania Spring 2016
UMASSD-CATANIA-S16S7G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 719
